#638125 05/18/03 04:05 AM
Is this the slow death of my headlight? Could I find the leak and seal it? What are all my options then?
Post 98 BTW.
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
U
U
Well I am not real sure how you could find the leak, but I guess you could remove it from the car, remove the light, then fill the assy up with water. Make sure the outside is dry. Seal it off and see if the water slowly starts to trickle out. Just a thought, not that anyone has done that. Just made me think of when someone posted about washing the inside of there headlight assy.
Come to think of it, they mentioned how to get the condensation out too! On a warm day, remove the headlight bulb and let the assy air out. The warm air will "dry" in the interior of the assy. Once it is dry, replace the bulb. If you have a good seal, with no air leaks, problem solved.
Hope some of this late night rabbling helps you out some.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
CEG road warrior
CEG road warrior
Condensation sucks. I get it bad after taking the light apart.
#638128 05/19/03 05:15 AM
I tried cleaning my headlights following the instructions to fill them with water and it didnt clean anything. When i took a closer look, the finishing on the headlights had chipped away. Now there are black marks where the finish washed away with the water.
'99 Silver SVT Quaife LSD Centerforce DF B&M Short Shifter DMD
Yeah, mine were wet for too long, and the water had ruined the reflective coating.
Anyway, the root of the problem was not a leak, but a clogged vent. The assembly has to be able to breath. I'm not sure where the vent is on the later headlights, but on the early cars, there was a white "button" on the upper outside corner of each assembly. Mine had been pushed in too far, effectively closing the hole. Pulling it out about an 8th of an inch kept it dry, once I had done the water/alcohol bath, but like I said, it was already too late when I figured it out.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
F
Smurfette
Smurfette
F
I've been having moisture problems as well on my GL.
They wouldn't pass me for NH inspection because of it.
I originally thought it was because the bulb itself wasn't in there tight enough (because it wasn't). so I pulled out the bulb and attempted to blow the water out with my air compressor, and made sure the bulb was set in there tightly this time. It passed inspection, but a day later there was a ton of moisture again.
I believe my Haynes manual (pre-98) has a how-to on how to replace the seal inside the headlight.
I was considering attempting it, but not sure how difficult it'd be to get a new seal.
I did a search of car-part.com and found numerous headlights in my area for $50. This may be my alternative.
Well, I got bought my car from a staelership, and they did a gov't inspection too, but passed the condensation, saying it WASN'T a safety hazard. Should I go back?
Pour some FOG-X in there, worked on my SHO....
99 Blk SE Sport 2.5 CD4E Euro Focus SVT Wheels 5 % tint Mesh Grilles w/indiglo ford KKM intake filter FMS 9mm wires Superchip Signal mirrors Fog lamp mod Dingless A6 sidemarkers Duals SVT springs/struts
F
F
I had that problem with my 98 Contour in one of the headlight assemblies. I pulled the bulb and removed the cover over the headlight level gauge. Then I used a hair dryer to blow air into the opening for the bulb, with the level gauge opening acting as an exhaust. It seem like it took several hours, but I finally got the interior dry. Compressed air could work fine, but I didn't have a source so that's why I used a hairdryer.
After reinstalling the bulb and level gauge cover I haven't had anymore water in the headlight going on 5 months.
Rick Steverson 98.5 Contour SE Sports Amazon Green Duratec ATX
I did and got water spots all over!
