Posts: 44 |
I've searched and found shields for the V6 but none for the Zetec. If someone can point me in the right direction i would appreciate it. I also read that people have made their own heat shield. Can anyone give some addvice about that?
1996 Contour GL, Zetec, ATX, Midnight Blue
Mods:
custom exhaust
after-market spoiler
Knauberized
Posts: 21,653 |
it's called foam board, you get it from your local crafts store. it's cheap, takes less than 5 minutes to make a heat shield. You just have to replace it every few months as it gets weak.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by CONTOURCODY: I've searched and found shields for the V6 but none for the Zetec. If someone can point me in the right direction i would appreciate it. I also read that people have made their own heat shield. Can anyone give some addvice about that?
same one for the Zetec
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 682 |
Originally posted by Kremithefrog: it's called foam board, you get it from your local crafts store. it's cheap, takes less than 5 minutes to make a heat shield. You just have to replace it every few months as it gets weak.
It took me 30 minutes to make mine, because it's fitted all around to allow minimal leakage, so the shape is complicated... but the original foam is still in there, I've never had to replace it. I just need to tape it back into position every once in a while.
Posts: 2,094 |
Hector needs to get a pic of the heat shield he got this past weekend.
'95 GL White
I've got mods.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by LoCoChick'95: Hector needs to get a pic of the heat shield he got this past weekend.
Hector needs to install it!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,094 |
Originally posted by LoCoZ2.0: Originally posted by LoCoChick'95: Hector needs to get a pic of the heat shield he got this past weekend.
I'm sure you'll get to it this weekend.
'95 GL White
I've got mods.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by LoCoChick'95: Originally posted by LoCoZ2.0: Originally posted by LoCoChick'95: Hector needs to get a pic of the heat shield he got this past weekend.
Possibly!
Hector
257HP/259TQ
160HP/141TQ
Posts: 44 |
Originally posted by ZetecRacing: Originally posted by CONTOURCODY: I've searched and found shields for the V6 but none for the Zetec. If someone can point me in the right direction i would appreciate it. I also read that people have made their own heat shield. Can anyone give some addvice about that?
Thank you for letting me know that. Is there any modifications needed to make it fit or does it bolt right in the same way as on the V6?
Mods:
custom exhaust
Knauberized
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by CONTOURCODY: Originally posted by ZetecRacing: Originally posted by CONTOURCODY: I've searched and found shields for the V6 but none for the Zetec. If someone can point me in the right direction i would appreciate it. I also read that people have made their own heat shield. Can anyone give some addvice about that?
WILL HAVE TO BE MODIFIED!
Hector
257HP/259TQ
160HP/141TQ
