Ok everyone.........before you spend money buying Compressors and such...there are a few things you need to check.
First....the freon may be low. As stated, if it is low the Compressor will NOT turn on. If your A/C didn't feel as cold recently before it quit...this is the most likely culprit.
Second...the fans not working may be a sign of something else.....bad underhood wiring. If you have under 100,000 miles and have any visible signs of insulation cracking or exposed wire....Ford will replace this under recall
99M03.
If you have cracked wiring and insulation...diagnosing the problem will be nearly impossible as the problem will be short circuited wiring. I just replace the fourth and final wiring harness....the worst one...the main power harness. It supplies power to the entire vehicle. My A/C stopped working and I did everything to diagnose it myself.....only to find out that key wires going to the cooling fans were shorted out as were wires going to A/C sensors.
I hope for your sake that your car is under 100k. If not be prepared to spend around $700 for the harnesses and about 24 hours worth of work to replace all four harnesses under the hood.
Caution..if you find any cracked wiring....DO NOT mess with them. Leave them alone until you are having it fixed or have the new parts in hand and are ready to begin. If you touch the harnesses you will cause other shorts that will prevent your car from running. Trust me...I know from experience!!!!
Good Luck!
