I posted a couple of weeks ago regarding my engine overheating, and the mechanic wanting to change the head gaskets. I took the advice you guys gave and replaced the water pump first...good thing I did, since the impeller was split in two.
I got the whole thing back together, and the pump seems to be working, unfortunately, I cannot get the engine to idle at anything over ~500 RPM (it usually just stalls out). I've found I can actually drive the thing as long as I don't have to STOP.
I've read the Haynes manual and it gave a procedure for having the engine re-learn the idle. Doesn't seem to work for me, though. It never idles at the right speed.
Any ideas on possible causes? I did notice when I took the battery out, the cables were all corroded, and it doesn't seem to have a full charge (even though it has no problems turning the engine over). Should I replace the battery, or just head straight for a dealer. I feel I'm getting to the limits of my mechanical abilities...
