avu3 Offline OP
Ok, onward from my previous post.
I made the car start - it had a hideious noise when cranking, but it started. Subsequent starts it does not make a noise. (98 SE Sport V6 ATX)
The problem is it idles at 1300 rpm. It will accelerate up to 4000 RPM, but then runs rough up to about 4500. At 4500 it acts like it hits the limiter....
I'm going to clean the throttle body and IAC, replace the fuel filter. Anyone else have any ideas?
Thanks!
Scott
Ford cannot build a car like this (1966 tbird) today because the US government says it is not safe. It has no crumple zones, air bags, or other safety features such as what you'll find in say, a new Toyota. But hit a Toyota with one of these and see who loses!
- Gary Tayman
That sounds like you have a clogged Catylitic Converter(s)..................check your exhaust....see if they sound right or push out a normal amount of air.........
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile
Moderator of the Florida Contour Enthusiast Group
In park, early rev limiter kicks in on ATXs. Sort of a transmission protection feature i guess. :rolleyes: Might want to check the plugs/wires as well as the hoses leading to the intake area (for leaks).
Scott
avu3 Offline OP
Thanks for the suggestions. I started the car when I got home and it started right up. Big Jim told me about the rev limiter, too, so I drove it around a little.
Seemed to run oddly the first little bit, but once I warmed it up ran ok.
I am still going to change the FF and clean the IAC and TB, it was just too late last night to do it.
It needs new plugs and wires so I will probably try and change those, too.
Thanks,
Scott
- Gary Tayman
