avu3 Offline OP
Cranks fine but won't catch. This happens off an on but usually it catches by about 10 seconds. Not today....
From the search feature I have gleaned to:
Check the CPS
Replace the fuel filter
Clean the IAC and TB
Any other suggestions I should try?
Thanks in Advance,
Scott
Ford cannot build a car like this (1966 tbird) today because the US government says it is not safe. It has no crumple zones, air bags, or other safety features such as what you'll find in say, a new Toyota. But hit a Toyota with one of these and see who loses!
- Gary Tayman
same thing happens to my tour I just ordered a coil today to see if thats a probem maybe you should check the resistance of the coil and spray a lil gas in the intake see if thats the problem
gas=starter fluid if the coil fixes my starting problem will pm to let you know but for now good luck
