Hey everyone, I hope someone can help me out here. I went to install me new H&R springs yesterday and let me tell you I didn't get very far.
Per Stazi's instructions:
Unbolt the steering tie rod from the knuckle and tap the rod out from the knuckle. Don't worry about striking the end of the bolt; its dog pointed and so direct impact should not damage the threads.
Well on the passenger side when I was taking the nut off and started to get the the lower part of the bolt(are thes ball joints?) the whole bolt started to rotate.
To see if this is what it was suppose to do I decided to move over to the driver's side to see how that would go.
I noticed that on the driver's side the rubber boot was already torn so I knew that it was going to have to be replaced anyway. Well the nut came off on the driver's side without the bolt rotating. Then per the instructions I took a 5lb. hammer and tried to pound it out to no avail. I added more WD-40 and waited about 30 minutes. Then I took the hammer and tried again. No luck. My last attempt was to try a pickle fork and that only tore the rubber boot some more.
Any way I decided to give up and tried to put it back to drivable condition. Driver's side went fine, besideds the torn boot. The passenger side I couldn't tighten the nut back up because the bolt kept spinning. Now I have about an inch and a half of play so it is not safe to drive.
So now the question is, can I replace these ball joints(if they are ball joints) or do I need to take it to a shop? I noticed that they thread onto the rest of the sterring rod so does that whole piece need to be replaced or if they are ball joints do they press out?
Sorry for the long post, but I need help because it is my daily driver.
Thank you,
O3
