Posts: 44 |
Is this a common problem with high mileage Zetecs? Has anyone else had this happen?
1996 Contour GL, Zetec, ATX, Midnight Blue
Mods:
custom exhaust
after-market spoiler
Knauberized
Posts: 6,910 |
I am not sure but I would seem to think so when i changed the timing belt on m car at 104k the tensioner was worn down and had two cracks, 180 degrees apart from the center almost to the outside  since it is plastic it can get brittle with age and other stuff like that
- 95 Mystique LS - Zetec/5spd
Posts: 4,639 |
how much did it cost to replace. did u do it yourself. i think my gl can use it replaced.
Hugo AIM:omegazodiac
Posts: 6,910 |
new belt, three pullies, tension spring, serpentine belt was around $300
we did the work ourselves. it wasn't to bad if you have a good set of basic tools and know-how. The Ford service manual was very helpful also.
the spring was used to tension the tensoner pully but it doesn't stay on the car
Posts: 21,653 |
Originally posted by brapple: new belt, three pullies, tension spring, serpentine belt was around $300
crap,, i know i should do it soon, but that's a lotta $$$$.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: Originally posted by brapple: new belt, three pullies, tension spring, serpentine belt was around $300
I spent $100 for all the same parts!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 12 |
mine broke as well, into 3 different pieces. I got the tensioner and spring w/ pin for under $90 from my local ford dealer. installing the new one seems easy(I'm still waiting on the spring) Pick up the Haynes manuel for some help.
'97 GL
'95 Escort lx
Posts: 44 |
Originally posted by hmouta: how much did it cost to replace. did u do it yourself. i think my gl can use it replaced.
I had mine done at a shop cause i figured if that went i should have everything checked on and replaced if needed. I can't remember what all was done but after a complete tune-up and all the parts replaced it was around $300.
Mods:
custom exhaust
Knauberized
Posts: 84 |
Same job without the serpentine belt..........$700.00 canadian. . $200.00 of that was labor. All parts bought from Ford.
96 Teal Contour
Zetec ATX
96K's
Posts: 4,639 |
the s belt was just changed. so thats done. so i'll need new pulleys too? a new timing belt wont be enough? my mechanic said the job would run about $300. just trying to see if i can do it myself w/ a new timing belt.
