#58585 04/16/02 08:14 PM
Check engine light came on the other day. Took the car to an auotparts store to have him check out the code, but we couldn't find the plug in! Where the heck is the diagnostic plug at? frown frown
Brandon Mendenhall
'99 CSVT # 229 of 2760
'77 280Z "Tomohawk"
"Never rub another man's rhubarb!"
#58586 04/16/02 08:23 PM
Just above the fuel pump shutoff switch. It faces directly down and is at the left side of the trim piece under the steering column. Its pretty easy to see if you kneel on the ground and look up towards the fuse box inside the passenger compartment. HTH
