CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by blury:
As you can see in this photo my timing belt is in the exact same spot yours is in. It wasnt making anynoise i just like the looks of it better with it off.
....but how safe is it. There is a cover there for a reason.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 4,639 |
Originally posted by bentleywarren: Originally posted by hmouta: any chance the washers can come loose. where exactly did u place them.
I threaded the bolts that hold the cover in place through the washers, so they can't come loose, as long as the bolts are in place.
sweet thanks alot. i'm going to do that
Hugo AIM:omegazodiac
Posts: 13 |
so where is the tensioner located? i took the upper timing belt cover off and my belt looks fine. also, i got a procedure on how to replace the timing belt and it looks kinda hard. has anyone actually done this themselves? id like to kno what u did especially since its a tight space
96 Contour GL I4
hasnt been on the road for a year, tranny problems.
nuf said
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by i4getlots: so where is the tensioner located? i took the upper timing belt cover off and my belt looks fine. also, i got a procedure on how to replace the timing belt and it looks kinda hard. has anyone actually done this themselves? id like to kno what u did especially since its a tight space
Tensioner is located right under the cam gears.
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,291 |
I've had mine off for a year and I live in the dirtiest environment you could find. No problems here
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by D Davis: Originally posted by LoCoZ2.0: Originally posted by blury:
But with my luck?
Hector
257HP/259TQ
160HP/141TQ
Posts: 682 |
Originally posted by LoCoZ2.0: Tensioner is located right under the cam gears.
I suspect the average owner is more likely to have trouble with idlers than with the tensioner. The problem with the idlers is that their diameter is small so they have to spin really fast, so the bearing wears out. They're located down hear the crank pulley.
Posts: 405 |
Ive been down dirt roads at 65 today i was just drove through many spots that had about a foot of water and the other day i was trenchal downpowers with 60 mph head wind. Still no problems. Thats about as extreme as you going get in driving conditions. I think the cover os there mainly to keep you from touching it with your hand while its running you know like the "caution do not touch moving fan blade" thing.
95 Tour ATX Zetec
EGR Block OFF
Polished TB
Polishe Vavle cover
Energy suspension Greaseable sway bar bushings Front and rear
Red interior lights 1/2 done
Home made short ram intake
Custom Grills
Watch this space grow
Posts: 569 |
The same spot as whos. Not mine. You can see the gears on yours on both sides of the belt. Mine was actually hanging over the side a bit.
....Brad
Your mom thinks I'm hot!! But my wife rocks!!
99 Mestique Zetec ATX, 96 4Runner 5speed
Mods? Um gotem.
VFA-94VFA-122 VFA-115
Posts: 716 |
as did mine, but its gone now.
95 GL MTX Zetec, Carbon Fiber hood:
*neoprene seat covers
*new SVT rear bumper
*Proud Owner of 1962 Chevy Corvette 427
