Posts: 1,108 |
I just broke one of my front wheel studs any tips on replacing??
Kick Ass don't Kiss It
Posts: 132 |
take the brake caliper off and the rotor and it should pound right out, then just pound the new one in. Pretty simple if you don't strip the caliper guide pin (7mm torx socket i believe)
95 T-Red SE MTX Eibach springs, Custom cat-back exhaust, Cross-drilled front rotors, Momo air race leather shift-knob, Kenwood head unit, Kenwood 600w amp, 2 12" Infinty's, 18" Tantrums w/ Yoko Paradas, SCA CAI
Posts: 3,636 |
Yeah,
What he said.
Althought, I'm not sure I'd pound the new one in. However, if you can get enought through to get some threads, you can use some washers and the lug nut to draw the new stud into place.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 168 |
I wouldn't pound it directly at first or you'll flatten the end that still needs to go through the hole! I just did one recently on a 240sx using a sturdy rounded chisel tip and a hammer, putting all pressure in the center of the bolt. Then when it was backed out about 1/4" I hammered away at it and it popped right out. A little rust eater helped too.
As far as getting a new one in, get some washers that will fit around it, about 1/4" worth. As you put the new stud in, push it to where it stops with hand force, put the washers on it, then start to work on the lug nut, which will pull the bolt all the way through since the washers will cover the 1/4" non-threaded gap. Good luck!
Ryan M. Taylor 1996 GL V6 ATX Desert Violet {__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __} http://rmtaylor.webhop.org AIM: Vinnland990
Posts: 1,108 |
Thanks for the replies I'm going to try and fix It.
Posts: 4,042 |
Piece of cake, took me 30 minutes to replace mine.
Take off caliper and rotor, pound out the old one, put in the new one. Simple as pie.
John
