Posts: 15 |
Has anyone else had problems with the Yokohama AVS ES100?? Mine are 225/50/15's, and I purchased them about a month ago. They are the loudest and most obnoxious sounding tires I've ever purchased. The interior resonance/drone is so bad that normal conversation is next to impossible, and the radio volume must be turned up over half way just to hear it. The resonance is transmitted through the steering wheel column and the brake/throttle/clutch pedals. I don't have a serious vibration, just a highly aggravating drone at all speeds and rpm's.
At first I thought a belt in one of the tires had broken, but the tire dealer did not find a problem when inspected this evening. The dealer re-balanced and rotated all four tires, but this did nothing for the drone.
When I took the car back the second time tonight, the dealer could only figure the 225/50 size was too large for the 15" stock wheel, and suggested reverting to the 205/60/15 size tire. Could I be having suspension problems that are aggravating the problem, thereby resulting in the drone/interior resonance?????
Any feedback will be greatly appreciated.
Thanx!!!!!!!!!!!!
Nathan
Posts: 125 |
If they are directional tires are they installed correctly. Look at the arrow on the side of the tire.
Woz
2000 Contour SVT #136
Black with Blue leather
30% tint all around
12.2" Wilwood Billet NDL
PS: I hate ALL Ford Dealers
Posts: 15 |
Thanks for the tip....the tire is directional and is rotating in the proper direction.
Nathan
Posts: 2,353 |
No problems with mine, in fact they're much quieter than the Dunlop 8000's that were on there before.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 245 |
Originally posted by path914: No problems with mine, in fact they're much quieter than the Dunlop 8000's that were on there before.
Ditto...compared to the stock BFG KDW's with similar miles, these are total stealth!! Your tire dealer might be onto something...what is the width of the 15" rims ?? TireRack recommends a rim width of 6"-8".
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=AVS+ES100
Regards, Art
2004 Velocity Red RX-8
*Racing Beat Intake and Exhaust
*Grand Touring Package
*Red/Black Leather
*Fender Strakes
*Rotary Accents
*Xenon HID's
*Bose
Posts: 4,713 |
Mine are quite quiet. I haven't had any probs with mine. Sorry I can't help.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 140 |
I have the 205/60/15 and no problems. I'll bet its the oversize causing the problem.
Posts: 23 |
Nathan/others
Anybody find a cure to the road noise on the AVS ES100?
Here are the facts: Total miles on tires: ~12,000 Rotation: 4,000 & 8,000 miles Size: 225 width on OEM '99 SVT wheels Pressure: Have tried 35-46 psi Direction: Yes, they are mounted correctly Alignment: Checked at NTB, ok per Ford Spec, RH and LH front off by only .03 deg Balance: Balance redone at 4,000mi Wear: Measured with plenty left, wear even
I had these tires put on as as replacement for OEM KDWs. Intitially I was very happy with road noise (the description of "stealth" is appropriate). Recently replaced tie rod end (hence the alignment) about 2500mi ago. Last 1000 or so miles has seen an exponential increase in road noise. It gotten unbarable, just like Nathan described above. For example, an empty pop can in the driver's side cupholder resonates so much I can't hear the radio at normal listening levels. This sound is terrible! I have only 6 months on these tires and I got over 3 years out of my KDWs--so I don't want to replace them. Anybody have any ideas? I thinking I should complain to Yokohama or Discount tire--I would rather have my worn KDWs back at this point...
'99 SVT Contour, K&N, B&M, DMD, 'Foamed' Chassis
Posts: 4,713 |
I dunno, but mine are quiet.  Maybe your wheel bearing(s) need some grease.
Derek
Scion xB 5-spd
Posts: 1,616 |
Not trying to be a dick or anything, but when you buy "performance" tires at the cheap price of the ES100s, something's gotta give...and as you're seeing...its development $$$. Tires that are researched and developed properly to address these concerns for the lifetime of the tire cost $$$...and adds $$$ to the cost of the tire.
My $.02
