Posts: 117 |
whats up i took my tour to this mechanic and said i need a TPS sensor i was like ok and left the shop saying to myself what the f__k is that any one knows before i spend the 150.00 dollars if u also need to know its because when i come to a stop at a red light or stop sign or just stop to look at some ass my car starts to jerks and sometimes turn off please let me know what u guys think or if u heard of this sensor
Posts: 76 |
Throttle position sensor. It is on the throttlebody. Tells the ECU how much load the engine is under as well as feedback for a stable idle.
Posts: 6,910 |
throttle posstion sensor
located on the side of the throttle body
not sure but the only thing that it really does is for an atx, other then that it is a check for other sensors
- 95 Mystique LS - Zetec/5spd
Posts: 117 |
thanx guys so i should spend the 150 to fix it
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by pnice: thanx guys so i should spend the 150 to fix it
Yes, there is no way around it.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,291 |
Originally posted by LoCoZ2.0: Originally posted by pnice: thanx guys so i should spend the 150 to fix it
Don't be misleading, Hector.
No, you don't have to spend $150 to fix it. You can buy one off of fordpartsonline.com for ~$42 and change it yourself. It's only held on by two bolts, IIRC.
Posts: 6,910 |
Originally posted by D Davis: Originally posted by LoCoZ2.0: Originally posted by pnice: thanx guys so i should spend the 150 to fix it
yes it is mounted with two screws, mine were very hard to take out so be careful. had to use vice grips to get them out and had to replace them after
Posts: 117 |
i think i better take it to a mech. i dont even know how this yhing looks
CEG road warrior
CEG road warrior
Posts: 17,248 |
Whoops! Yeah and the other $100 to use for mods!
Hector
257HP/259TQ
160HP/141TQ
