#626410 05/06/03 03:57 AM
9
9
Hi,I am a newbie here.I have all the wiring in my car for the fog lights but i can't seem to find where the relay plugs into.Maybe I have the wrong relay.My dad gave me the car but I have been taking care of it since he bought it in 97.He had an alarm installed in it right after he bought it so I am not sure If they cut the relay harness or not.The relay I have is white and square but I found a plug but it fits a round relay or harness into it.I noticed that below the fuse box there is a block that harnesses plug into so I am unsure if i just need a new harness or i got the wrong relay.The plug is right near the headlight switch that is why i ask if that is where the relay goes.Any and all help would be greatly appreciated.The contour is a 96 gl with the zetec engine.
Thanks,
Fred
#626411 05/06/03 04:35 AM
H
H
Welcome onboard.
This thread will give you wire colors you should be seeing at relay plug/connector: fog relay plug
Presumably you will also have to install fuse noted as well.
