#58401 04/15/02 03:02 AM
After driving my car for about 15 min. it looses all its power over 4k rpm's. Example my wife blew me away in her suburban and then laughed at me. Any heip would be great. Thanks in advance
V
V
I'm no expert, but sounds like maybe you need a tune up. Sounds like the same thing that happened to me.
Kyle K.~
I don't know much about cars. I'm just starting out. That's why I'm here right?
1995 Mercury Mystique GS
2.0L DOHC
Not too much else.
Kyle~
Secondaries probably not opening due to IMRC problems. You should be able to see the IMRC linkage move when you operate the throttle by hand and get the RPMs over about 3800. Fairly common problem. Try a search on IMRC to see what others have done.
Scott
Look at the wiring for the TPS. Mine was run over the rod that opens the front runners. Amazingly, that harness was hard enough to block them from opening all the way. Re-routed and no problems now. just a thought...
Jim
98 EO CSVT #761
I
I
Suburbans are pretty quick.... i wouldnt worry about that.... smile
"I wish my CONTOUR had twin turbos"
