I have a 98 Contour SE, 2.0L. Only when making right hand turns, the car will all of a sudden try to fishtail slightly back left. Sometimes it will do this several times.
The left control arm was changed (thought front bushing was possibly bad), the strut, ball joint, wheel bearing is all new. Front end-alignment has been done.
I know the car was previously whacked in the front left. What if the engine/trans was not centered properly? What if the sway bar was slight bent ? Just desperately grouping for possible answers. HELP!!!
