#58341 04/14/02 06:15 AM
starman Offline OP
My 2000 Contour 5spd, V6, has had 5 fuel new pumps between 35,000 and 45,000 miles. Ford has kept replacing them, but what gives ? They've found debris in the pump screen. One mechanic says it's dirt, one says it's not. He says it looks like gasket material, or something. They've cleaned the tank, but it keeps happening. The car starts stumbling, a brief sit by the side of the road can get the car running again for a short while. Eventually the car becomes undrivable until they put in a new fuel pump. Mileages between fuel pumps has ranged from 50 to 2,000 miles. I have changed gas stations with no effect. My Dodge diesel, sitting in the same driveway, has had no fuel contamination problems. Any insights would be greatly appreciated. Thanks.
#58342 04/14/02 06:29 AM
I just posted on this receintly so you may want to look for it.
There have been a lot of problems with the returnless system. It seems that the pick up filter screen is very small and plugs with very little contamination on the screen. The screen is ultra fine and is only about 2 1/2" in diameter on the bottom of the fuel pump module. I do believe that it is the fuel that is causing the problem but that the car is not nearly tolorant enough of the problem. Most pick up screens are a sock on the bottom of the pick up tube that has a much larger surface area than this little disc.
I have been told (but I have not confirmed) that there is still such a sock further inside the pump module and that by just removing the screen on the bottom that gets clogged too easily that you will still have satisfactory filtering prior to the pump.
If the technician at the dealership is willing (he may feel that it would damage a part that may need to be returned to the factory so he may not be willing), suggest that he remove the screen at the bottom of one of the old pumps and see if there is still another sock filter inside. If so, a solution to the problem would be to just remove the screen that plugs too easily. This is a recommendation that I had from another dealer that was having the same problem.
Let us know how it ends up so we can all continue to learn.
Jim Johnson
98 SVT
#58343 04/15/02 01:02 AM
E
E
eek Wow! I thought I had problems being on my third pump!! mad
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#58344 04/19/02 12:07 PM
There are two filters in the FDM for the returnable fuel systems; a jet pump filter (outside) and pump filter (inside).
Is there any way to determine by VIN or engine type, if it has returnable or returnless fuel systems?
#58345 04/19/02 04:49 PM
Look under the hood....two connection to fuel rail = return....one = returnless... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
