Not trying to be an ass, but do a search. That's what it's there for...
What you'll find is that you probably need to cut out a few sections of the fender liner, as this is where it's probably rubbing. you should be able to jack the car up and visually spot exactly where the tires are rubbing. AND, there's a small section around the rear fenders that is rubbing, too. As Pascal once explained, feel the fender well lip at about twelve o'clock, then work your way towards the rear of the car. At about where the rear bumper cover attaches, there is a spot that sticks out a bit further. Check here, too.
BTW, I'm also running 19x8 Axis 7 Mod with 225/35/19 Nittos, Ground Controls sitting very low, and Koni 5 ways with no rubbing in rear, even with full load. I do have a slight bit of rubbing in the front, but that's because the car is so low. (The price you pay for the look...)
