#58221 04/12/02 05:50 PM
BIGS Offline OP
ive been dealing with this little piss ass problem for like 2 weeks now, i got a cel and ran the obd2 test to find i needed a O2 upstream sensor in bank 1(back of he engine). now i looked at all the 4 O2 sensors and they all look the same harness wise. now the back one on the engine looks like a extreme ***** to get to. i bought the motorcarft replacement online for 75 bucks(as oppsed to 130 at the dealership) and the harness looks different from the stock. has anyone replaced this sensor, and when you did, did the replacment harness body look any differnt than from the stock one? i went to three diffrent places, all with the same part, so its got to be the right part, but the housing looks different, before i try getting to it, anyone know what im talking about??? confused
98 SVT
MODS:
Something or another
#58222 04/13/02 01:42 AM
Dont know nuttin bout no SVT. wink
But I can tell you that replacing the right O2 sensor on my 95 LX was a Major League Pain in the Butt. If you do a search for O2 sensor you should find multiple postings about this.
I purchased my Motorcraft O2 sensor online also for $53 each. The connectors matched up perfectly. Note that the 95 D-tec uses the
DY-828 F5RZ-9F472-AA sensor.
Good Luck
Jab
Learning about cars from my Contour 95 LX - PLEASE do NOT BREATHE on my wiring harness! I can't afford a new one!
#58223 04/13/02 02:25 AM
Originally posted by BIGS:
I went to three diffrent places, all with the same part, so its got to be the right part, but the housing looks different, before I try getting to it, anyone know what im talking about??? confused
Unless you went to THREE DIFFERENT DEALERS, the people you spoke to, all have no idea of what they are looking at.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#58224 04/13/02 02:34 AM
Q
qaz Offline
Q
The Contour does not use the same O2 sensor connector as other Ford cars (at least for the upstream sensors). The one on the Contour is a square/rectangular 4-pin connector. The one on other Ford cars (and maybe the Contour's downstream sensors, can't remember for sure) is a round 4-pin connector.
All else fails you can always cut the plug off your old O2 sensor and splice it to the wires from the new sensor (I'd only do this if returning the new sensor is a pain).
Brian
#58225 04/13/02 07:27 AM
before you replace any, do this. i had a cel a few months back. dealer told me code was po171. o2 sensor. so i disconnected the front o2 sensor, cleaned the connections and blew them out. reset the computer and the cel hasn't come on since. alot cheaper to do this than replace something that may not need replaced. maybe you have a dirty connection or something. just fyi.
i will always have a comeback! :o)
#58226 04/13/02 11:20 AM
BIGS - search the forum archives for part number. connector configuration and replacement procedure - been there, done that.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
