Sometimes when I am backing out of driveway and have wheels turned while going down the curb into the road I hear kind of a clunk as the front wheels are going down the hump of the curb.
Is this anything I should do some further checking on?
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
Lee Offline
Lower control arms or loose strut mount.
The lowers are most common on older tours or ones that are driven hard. Luckely for me I have both of those problems.... :rolleyes: frown
Lee Cox
In life begins responsability...
Project Car
Would I be able to see anything to tell me if either or both of these are a problem if I crawl under there...
Wouldn't strut mounts make more of a rattling noise on any kind of bumps and stuff at all sorts of speeds? I only have heard this clunk when wheels are turned and I go over bump at curb in reverse...so it is at pretty slow speed. The only other thing is a few times when I have turned relatively sharply at slow speed, like into a parking spot, steering did not seem quite right...not sure how to describe it beyond that.
I do have some suspension rattles too in both cars, but seem to be mostly from rear...which I understand is common, but just an annoyance.
Lee Offline
Well if you look at the bushings on the lower control arm they would be cracked if that's what is causing the problem. Another option might be that the rack and pinion is loose? Other than that I don't reall know.
Lee Cox
Project Car
Mine did the same thing. The cluncking noise was on the front drivers side. I took it in to Ford because it was under warrenty and they saide it was a Front End Link. Fixed it and haven't heard it since.
Swaybar end link? Ihave develpoped the same problem since i installed my shocks and springs. I had everything off the nuckle so i may have not gotten everything tightened back up all the way.
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
