paulc Offline OP
OK, '95 Contour LX V6ATX 70K miles. Just spent a whole bunch of money putting a new tranny in the car and now the thing's failing again. And ever since I had the tranny replaced the engine has run rough. So, while contemplating the upcoming battle over the transmission I thought I'd do a compression test. Well guess what? A bad cylinder!! Because of the circumstances that I had the tranny replaced I know it'll cost me a hugh amount of time and money again, even though I'll probably get the tranny replaced under warranty.
So, I'm thinking that buying a junked car (something totaled from behind?) and doing a sub-frame and up swap - motor, tranny, the whole thing.
My question is: what year/models are "compatible" with my 95 LX?
95 LX 2.5 ATX
69K-new ATX
70K-new H2O pump
Really, REALLY want a new exaust system!
The 95's are unique re vac operated secodaries etc & wiring.If the engine is the main problem any non svt 2.5 will fit the bill and swap manifolds & engine wiring harness over.....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
paulc Offline OP
Ahhh.... OK. That's a good detail to know! Thanks Terry.
95 LX 2.5 ATX
69K-new ATX
70K-new H2O pump
Terry, should one replace the manifolds and wiring harness as you instructed as a matter of course during an engine swap just to be safe or are those items different for every model year 2.5 Duratech and MUST be replaced for things to work properly? Specifically I'm wondering about my swap of a 96 2.5 for a 97 2.5. The more information I can arm my engine shop with, the more confident I'll feel. Thanks.
Luigi
1997 SE, black, MTX, BAT suspension kit, resonatorless, Dynomax Superturbo, Corbeau GTS-II driver's seat, seven spoke SE wheels, K&N, tranny cocktail, Mobile 1
Used 96 Duratech with 35K installed at 92.5K due to engine fire. Replace your water pump today!
