I just got my 96' Contour SE last saturday on the 6th and i opened the hood and saw the K&N filter but there was no box on it and there was a sensor that was not plugged (heat sensor i think) in, because of this my(check engine light is on) im pretty sure its because of this sensor not being plugged in. Can anyone help or tell me where i can get a box for my filter and how do i hook up the sensor and if the engine will light will go off after i do this.....plz help
The sensor your talking about I believe is the intake air temp sensor. This will not cause a CEL if it's laying around. This sensor would typically snap into a hole in the top of the airbox, near where the MAF connects. Does your car have a cone type K&N filter or a K&N panel filter attached to the top part of the airbox. (The bottom half is gone right?)
Yes the bottom half is gone and it is a cone type filter and + plus i didnt buy the car i got it as a gift so iam just tring to fix it and i did look for a hole but there is none alls you see is the filter connected to my engine and isnt connected to my fender and it has no box can i keep the air filter and put a box on it? then connect my air intake sensor??
