Posts: 21 |
For some strange reason which I cant figured out my reverse lights dont work in my '95 Mystique LS. I have read all about the housing filling up with water and all and it does do that but I have replaced the bulbs and all and no luck...any ideas?
Posts: 4,294 |
did you change the fuse? if it filled with water caused a short it would blow a fuse.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 492 |
Mine did it too. Cheap Ford wiring broke at the hinge bend line. Jim
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats".--H.L. Mencken
Bumper sticker,
OXYMORON #65 - Liberal Thinker
Posts: 97 |
See if you have power at the connector if not and the fuse is good it is probably your TR transmission range sensor is bad. that switches them on in rev.
1998 Contour V6 se ATX Black
Bassanni w/o resinators, modified intake box, DMD
New headlights w/ silverstar 9005's, blue neons inside, metal waterpump, pioneer head, pioneer 5x7
3 ways,2 10" subs, 800w amp, 17x7.5 motegi mr12 p215/45/17
Posts: 1,055 |
Originally posted by jthursby: Mine did it too. Cheap Ford wiring broke at the hinge bend line.
Jim
mine too, but that got fixed very easliy, that in turn blew the fuse, so check both.
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 9,196 |
You might wanna post this into "Trouble shooting", good luck
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
