N
N
I just purchased a '96 Tour w/ MTX Ztech and a standard cluster. I want to swap out the standard cluster with one with a tach. I have seen several on e-bay, but I am not sure which one will work. Will a Mystique cluster work in a Tour? And what years are interchangable (besides the '95 cable driven won't work in any other year.) Does it matter if it is a V6 or I4, MTX or ATX?
I have done several searches but come up with nothing specific. Any and all help would be greatly appreciated.
'95 Mystique ATX I4 2.0 134,000mi '96 Contour MTX I4 2.0 36,000mi My Rides
It has to be a cluster from a 1996,1997, or a 95 thats not cable driven. If you get a post 98 one the speedo won't work and your gas gauge will work backwards.
I found mine for $45.00 shipped from http://www.car-parts.com from a junkyard in TN.
www.ChicagoCEG.com 2006 White Grand Prix
beyondloadedse has done a post98 cluster (svt guages) with a pre98, he said it was plug and play pretty much. He said that everything worked fine. might want to look him up and send him a pm. Cause it will work.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
differnace it he has a Zetec and I can tell you it would work with the Zetec the speedo and the fuel gauge won't work on a pre 98 Zetec. tach and engine temp will though.
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
CEG road warrior
CEG road warrior
True....we tried that.
from what i have heard if you clip just the ground and positive wire, you just flip them around and it won't read backwards anymore. Easy fix, I have done it on a escort however. Haven't had any problems with it.
I
I
sounds like a good idea...but what about miles
having the wrong miles on the car would be annoying to me
CEG road warrior
CEG road warrior
Doesn't annoy me.
well, if the speedo says 130 top speed. well just pop out the old speedo and put it in your new set. works fine. Sometimes there is little modification to do. But nothing anybody here can't figure out.
N
N
As for miles, I have read it is not too tuff to swap odometers. So that does not concern me at the moment.
Right now I am looking at purchasing a '99 Mystique cluster. If I do so, from what I have read in the post, I have to swap two wires? The guy does not now if it is from an ATX or MTX, so does that matter? I believe it is from an I4 sense there is no V6 on the Tack. Is this correct?
Thanks for your responses so far!
