Posts: 10 |
I have a 96SE and have replaced the plugs and wires. I put new O2 sensors on, but any time it is under load it misses pretty bad. I know the secondaries are not opening, I have a new IMRC on order,but I don't think that would make it miss. Even when the car is just idling in park, I can step on the gas and the car misses while trying to rev up. One other point to note is that I have replace the plugs and wires several times and the car will run good for the first few thousand miles and then it will go back to it's old ways.
Any thoughts?
Thanks!
Posts: 1,399 |
What plugs and wires are you using? It could be as simple as plug choice.
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 548 |
could be sh1tty gas.. moisture in your fuel will cause that
try some STP fuel conditioner.. had that problem with a friends truck.. sounded like it was gona blow up and stall
98 contour gl, v6 auto
01 explorer sport v6 auto
2001gtp AT gmail DOT com
Posts: 4,714 |
Originally posted by Phil Rohtla: What plugs and wires are you using? It could be as simple as plug choice.
That or the coil is bad.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 10 |
I've tried several brands, Motorcraft, bosch. etc. and this I don't think it's a fuel issue, because the car has been acting this way for a while. Have you ever replaced a coil pack? That's the only thing I can think it may still be.
Posts: 270 |
Are you using double platinum plugs ?? I believe these are required equipment on the duratec
-chris
99 Se,MTX,TS.
Koni,Eibach,SVT Plastic,tunes,Opt Y-Pipe, Elky mesh, DMD, SVT BRAKING, Eo's, 95 Leather int.
Posts: 4,714 |
It shouldn't be hard to change, just make sure to get the plug wires on the new one in the correct order. Other than that its just a matter of bolting it on.
Hooray Beer.
Pictures
Posts: 21,197 |
THis is a spark issue. I don't know when you changed them or what you used but FMS wires with the Autolite double plats should work great. About $75 for the combo.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
