Posts: 68 |
On my way to work and on the way home my right front brake was grinding and making all sorts of funny noises. When I got home I looked at the wheel and it was covered in brake dust. (None of my other wheels have ever had a problem with brake dust) Do I just need to throw new pads on it or what's the deal with this? Thanks for the advice in advance so I can switch them up over the weekend.
2000 Silver Frost CSVT
Springs and wheels
More in the near future
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Grinding while braking or all times. If while braking more than likely you are metal on metal and will need new pads and rotors. If at all times, wheel bearings.
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 68 |
Yea I just bought new pads and rotors, now it's time to throw them on. I really should just pay someone....
Springs and wheels
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
I wouldn't!
I takes me 30 minutes to replace a set of front pads, so an hour if you haven't done them before. See if a local would be willing to help. If you are mechanically capable you really shouldn't have any problem. Get a Ford repair CD and only do one side at a time, as a reference. The outter springs are crucial!!!!
-Andy
Andy W.
Posts: 1,660 |
Originally posted by Andy W.: Grinding while braking or all times. If while braking more than likely you are metal on metal and will need new pads and rotors. If at all times, wheel bearings.
-Andy
Sure sounds like a seized caliper to me having worn out the pad and now running backing plate against the rotor. Don't just replace the pads, have the caliper replaced too.
Scott
Troll! '99 BMW 328i
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
99% of the time grinding is related to pads that are warn down to the baking plates. Siezed calipers are rather far and few between. You don't hear about if very often here. More than likely it's just time for brakes. And regaurdless of which he will need a new rotor!
-Andy
Andy W.
Posts: 505 |
Same friggin thing happened to me on Sunday afternoon! Right front brake started grinding when I brake! WTF! How much do rotors go for? Wondering if the BAT brake kit is a good deal? $225 for mintex pads and European spec rotors (either AP Lockheed or EBC) at all four corners. Anyone used this kit before? Hmm, I feel a search coming on!
Posts: 1,660 |
Originally posted by Andy W.: 99% of the time grinding is related to pads that are warn down to the baking plates. Siezed calipers are rather far and few between. You don't hear about if very often here. More than likely it's just time for brakes. And regaurdless of which he will need a new rotor!
-Andy
Agreed that it's the exception, but his description of having that one wheel covered in brake dust and never having had a dusting problem before indicates to me that something's causing the pad to wear fast and furiously, e.g., stuck caliper.
Scott
Troll! '99 BMW 328i
Posts: 5,975 |
Originally posted by JaySVT: On my way to work and on the way home my right front brake was grinding and making all sorts of funny noises.
Originally posted by MonkeyBiz: Same friggin thing happened to me on Sunday afternoon! Right front brake started grinding when I brake!
MY right front brake did the same thing....WEIRD.
