I just wanted to know some 0-60 times of your SVT Contours?
0
0
I think you would want to post this question in the general dept. You might recive a few more positive replies.
Anyways, I think lower 7 sec for me, I hope!
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!!
It's a chronic disease.
High 6's, low 7's since it takes a shift to 3rd gear.
Getting a chip (raised redline) knocks about 1 full second off this biased test since you can hit 60mph in 2nd gear.
The car isn't 1 second faster though. The gearing on the 'tour just isn't set up for taking this silly test. It's set up for real life driving!
BTW - this isn't a problem!
2000 SVT #674 - Check it out!
