#57749 04/06/02 09:24 PM
Im having problems with my secondaries. When I rev the engine the IMRC cable tries to pull the spring linkage (i see the wire cable getting tighter) but it seems like it doesn't have enough power to open the secondaries (like if the spring is too tight or the motor in the IMRC isn't strong enough) This IMRC is like 3 1/2 mths old only. Any ideas?
P.S. The spring is kind of hard even by hand but I can't imagine it getting tighter in a few months. And the ports aren't gunked up so thats not it.
#57750 04/06/02 11:06 PM
If you REV the engine quickly,
the IMRC should open the secondaries briefly.
When you're actually DRIVING the car,
the secondaries open around 3700 RPM,
and that's when you feel the second boost of power.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#57751 04/07/02 08:13 PM
Thanks but the problem is that when I rev the engine quickly the butterflies dont open. The cable gets tight nut doesnt pull them open. And the IMRC is less than 4 months old.
#57752 04/07/02 09:33 PM
Check the gearbox in the IMRC box,sounds like yoy have slipping/stripped gears on one of the shafts....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#57753 04/07/02 09:39 PM
The gears appear to be ok, and the motor winds the gears only enough to tighten the cable but not enough to open the secondaries. Any other ideas?
#57754 04/07/02 09:53 PM
Disconnect the cable at the linkage end and connect a spring balance...measure the amount of 'pull' on the linkage before the motor stalls or slips....
V6 MTX
#57755 04/07/02 10:16 PM
Well when disconnected from the linkage it will pull completely, then when I reconnect it it wont pull.
