Posts: 37 |
Hey guys after i put my h&r's and bat struts I noticed my back end kinda kicks out when I go over bumps! I thought it was just me but my freinds said soemthign about it too when they road in it! What can i do to fix this? Bigger sway bar? Rear strut tower brace?
Its a bird, its a plane...wait!..W.T.F.W.T..?
#1800 of 2150
Posts: 3,632 |
Using the proper tire inflation is critical.
I wish I could tell you what those figures are. I remember a post about it quite a while back. I would give it a good searching.
"Cobb - It's not just for corn anymore!"
Posts: 1,616 |
Originally posted by 2000greensvt: Hey guys after i put my h&r's and bat struts I noticed my back end kinda kicks out when I go over bumps! I thought it was just me but my freinds said soemthign about it too when they road in it! What can i do to fix this? Bigger sway bar? Rear strut tower brace?
BAT struts are gas charged...the internal pressure is like a "second spring" which attempts to maintain the strut at an extended state. Mine did the same thing at first. Give it 1000 miles or so, and they'll break in (or soften up), so to speak, and do that a lot less, if at all.
Posts: 37 |
Welp I have had my set up now for about 3000 miles and still does it! So what can I do to fix it??
#1800 of 2150
Posts: 1,616 |
Bigger rear sway bar will not help at all for rear end kicking out over bumps. Rear strut tower brace will minimize rear end "twisting" under pressure..also will not help. Poly bushes...that hold rear sway bar will also not help.
Try playing with tire pressures.
I run 33psi Front and 32 psi Rear on my set-up for road use. I have found that any more psi causes a degradation in ride that isn't benefited in handling.
Also...what tires are you running? Some tires have less bump absorbption designed in them...which could go hand in hand with making that rear end kick out...
Posts: 37 |
I am running the htrzII's I will have to play with the pressure! That is proobly my problem. I think I have them at 40 pounds right now!! thanks for the help!
#1800 of 2150
Posts: 1,616 |
Check this...I had some Yokohama es100s put on...tire place had'em at 37 psi...rear end was always coming around from my ausie bar. Talked to Terry Haines, who suggested the pressures I mentioned before...now the rear stays where it needs to! I think you'll be happy.
Also..use a good tire inflation gauge...the ones attached the hoses are dropped and abused...left out in the elements...usually a couple of pounds off.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Should have bought Koni's! LOL!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 37 |
thanks guys I will check I will fix it right away!
#1800 of 2150
