This really isn't Problem forum material - should've been posted in Wheels & Tires
Anyway, the way I understand it tire size is broken down this way: 195 is your width (in millimeters, I think)/60 is your sidewall height (it is a percentage of width)/14 is your wheel diameter.
I'm also on the prowl for tires. Let me break down my search for you a little and maybe it'll help you understand better.
My car calls for 205/60/15. However, I'm thinking of upsizing just a little and trying for a 215 width. Now, the dilemma(sp?) is do I find a shorter sidewall while I'm at it. A 205/60 sidewall would measure 123 mm; a 215/60 would measure 129 mm.
Doesn't sound like much, but on smaller wheels (14 & 15 inch) I think that would be more noticeable and throw off the profile of the car. With that in mind, I have decided to try and hunt down some 215/55/15 tires. That puts me at 118.25 mm sidewall height. A little off, but in the right direction (yes, I know the speedo would be inaccurate). However, I don't know that this size exists since I've had no luck in finding anything yet.
So, with that out of the way, take a look at
TireRack for good deals. Keep in mind, though, you'll still have to pay a local shop to mount and balance them.
HTH
