Posts: 79 |
Does anyone know the price of a new one? Are they hard to replace?
96 Pacifica Green GL Aftermarket JVC stereo White-Face HVAC Purple interior CTA Intake SVT Exhaust (coming soon) BNM White Face Gauges (coming soon)
Posts: 1,040 |
Adding it to the (coming soon) list is easy. I'll leave the details to the next member.
Posts: 654 |
Dont have a picture, but they are a piece of cake to change, except that rear one before the cat... Anyways, they just unscrew from the exhaust and unplug the wire. -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 68 |
I just received two Motorcraft OEM O2 sensors for my 95 Duratec. I purchased them from www.fordpartsonline.com. They were $53 each and the shipping was $6.00. I don't have any CELs or anything. I have done several careful mileage checks over the past month and have noticed my "eggshells on the gas pedal" highway mileage is down about 1.5 mpg. This is with correct inflation for tires, no A/C and no lights. Ambient temperature about 55-65F. I was willing to spend $100 from my "Contour R&D budget" as I am curious what effect if any I will see. My car has 107K miles on it. There are two sensors for this motor (95), one on each exhaust manifold. The one closest to the radiator looks easiest to get from under the vehicle, while the one near the passenger compartment looks easiest from the top after removal of the coil pack (easy - just remove 4 bolts). You will also need a 7/8 slotted socket designed for oxygen sensor removal/installation. You might be able to borrow or rent this. A new one is around $13. An open ended 7/8 inch wrench may work as well, and obviously will have more use in the future! I will post the mileage effect, if any, at a future date. Of course, if there is no change, I will mention that "the idle is smoother", "the engine lost its hesitation", "it no longer pings", or some other "keen" observation! Good Luck Jab
Learning about cars from my Contour 95 LX - PLEASE do NOT BREATHE on my wiring harness! I can't afford a new one!
Posts: 1,040 |
jabberjack: Only two? My 97 & 98 have four each!
Posts: 79 |
I have the Zetec engine. Do I still have 2 or just one?
Posts: 3,419 |
Originally posted by Jens(96)Tour: I have the Zetec engine. Do I still have 2 or just one? EDIT: Heck, I'll put the whole list here: 95 Zetec has 1 - before the cat 96+ Zetec has 2 - one before the cat and one after. 95 Duratec has 2 - before each precat 96+ Duratec has 4 - one before each precat, and one after each precat
Posts: 79 |
Thank You!
Posts: 146 |
Originally posted by PA 3L SVT: Originally posted by Jens(96)Tour: [b]I have the Zetec engine. Do I still have 2 or just one? EDIT: Heck, I'll put the whole list here: 95 Zetec has 1 - before the cat 96+ Zetec has 2 - one before the cat and one after. 95 Duratec has 2 - before each precat 96+ Duratec has 4 - one before each precat, and one after each precat[/b]where about are the other 2 before and after the precats,,,,,I can only notice just the 2 that I replaced before! And at this time,,,I am having sluggish performance when I take off! ConTourST. :rolleyes: 96' SE V6 ATX Dual exhaust KKM THF
Posts: 68 |
Horseydug,
Yep as PA 3L SVT states in his very typical informative post, the 95 D-tec has only 2. At 100K miles, my car passed EPA emissions testing very easily - used only about 20% of the allowed tolerance in the worst case. Are FOUR sensors really needed? Anyone know why they were added?
Jab
