Yep, I made it to forum. Thanks for the tip.
My SVT: Its a 98 SVT. 75k miles. Idle is fine.
The dealer in Grapevine changed out the cam positioning sensor, but said check engine light might come on as the code was intermittent prior to the sensor changeout. If light came back on, said that might be something in the wiring harness - it did about 75 miles later after the code reset. He even suggested that it might be EM interference from something.
Something to note: Prior to this last trip to dealer, In cold weather (about 2 months ago), the engine light was intermittent. It would come on right after a fill up then go out.
Accleration/response does seem effected with light on. Like I lost about 10 horses..
Anyone else seen this problem?
thanks,
Jim
