Welcome onboard.
Replacing blown fuse with higher rating in faulty circuit could cause wiring meltdown, definitely not recommended. Fuse is blowing because of intermittent short somewhere, possibly under console.
This thread will give you some general info re fuse 34 circuit and probable cause. Read it first and then post again if you require further info or assistance.
fuse 34
p.s. Including car info in post or sig usually helpful. You may wish to review rule 4 in the Forum rules above, regarding your current sig.
