#57380 04/03/02 05:07 PM
okay, what is the most likely culprit...
CEL comes on, stays on for a week or so...
then it goes off, stays off for awhile... when light is on performance seems to drop off, but not too much
i have a weapon R intake and a Shoshop catless ypipe... thanks for help if any...
1999 T-Red Contour SE Sport
#57381 04/03/02 05:13 PM
N
N
no cats
I think if you start messing with the emission systems on the cars it affects the performance.
could be the o-2 sensors.
But don't quote me on that.
#57382 04/03/02 05:16 PM
Without the fault code from the PCM, it's hard to be accurate. First "guesses" would be gunked up EGR, dirty MAF sensor, and then bad upstream O2 sensors. (I just see that Nate beat me to it :p )
Scott
#57383 04/03/02 05:17 PM
I heard that if the gas cap does not provide a good vacuum, then performance will drop and according to the Contour manual the CEL will reset itself after three engine restarts.
I'm no mechanic, so take what I say with a grain of salt.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#57384 04/16/02 04:24 PM
This sucks, ford wants 100 bucks to check it and autozone wants 130 for the code reader... grrr... The CEL light came on last night, while driving to work this morning it turned off... geee wiz... and performance is affect, accel while light is on is bad
#57385 04/16/02 05:58 PM
9
9
I would just pay the $130 for the code reader, you will probably read a code more than 1 time, so that will pay for itself after 2 readings from the dealer. Sometimes Autozone/Napa/O'reilly will read your code for you for free, so you might want to check a few stores and see if one of them will do it for free. -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#57386 04/16/02 06:05 PM
Most often, the CEL is an oxygen sensor light, especially when it turns itself 'off'. If mine stays on and everything 'seems ok' I reconnect the battery and allow the computer to re-learn its settings. The worst I've experienced is the 'OSL' was intermittant until 're-learning' finished.
