momma Offline OP
NEW HERE LOOKS LIKE LOTS OF INFO.
AND NICE HELPFUL PEOPLE
Here is my problem hope you can help.
Was driving car was doing just fine and the
o/d light starts blinking.Pulled over checked
the fluid was low add fluid turn the car off
stared it back up light was off. When I go to
pull out the thing was REALLY Slow at shifting
between 10 & 20 mph then runs good when I get to about
45 mph the light will start blinking again. My
beginner driver hit a building the other day
could there be something knocked lose that would
cause this? DH is in the construction business
and is working out of state. Any information
would be GREATLY APPRECIATED
This is an Automatic
96 contour
H
H
Welcome onboard.
Doubtful accident is related unless it caused loss of fluid; any loss is cause for physical check of transmissiom and fluid hoses to cooler at rad.
My personal experience posted in this recent thread:
Click
You can do a search on o/d light, but I'm afraid there's no definitive answer I've seen to-date.
My car does this as well, though getting your transmission rebuilt is probably not the answer, as mine was rebuilt just last year and is still under warranty. When I am on the highway, I drive for about 15 minutes, and the OD light strts flashing. This does not happen when I am driving around town. When I pull off of the highway, my car shifts really hard for a while, eventually going back to normal. I have never encountered anyting like this, but it's good to know that I'm not the only one with such an odd problem.
1996 Contour GL AT, 2.5 V6 No mods, rollin on 14's with hubcaps, 116,000 miles, and still havent been beaten by a ricer.
A fluid change may help but the flashing OD light usually indicates more serious problems. When you have the fluid changed make sure to use Mercon fluid. Some have had some success with adding some Lucas transmission conditioner to the fluid for smoother shifts. There is also an elecrical signal connector on top of the tranny that should be checked and reseated.
I had the exact same problem it took me a whole summer and ford a converter, two transmissions, computer, and speed sensor to figure out whats wrong. Your wires are throwing your speed sensor off. Either you just changed your wires(hi performance type) or your wires are bad. But I'm almost sure of it. Your speed senor thinks your car is going 50 mph at idle. Thats with all the shifting off idle and low speed and such. But stock replacements back on it.
I hate to tell you this, but the same thing happened to me back in October. Turned out my torque converter went out. Had to have the tranny rebuilt. Runs fine now.
2004 Ford Freestar V6 Boogity Boogity Boogity, Let's go racin Boys!
N
N
yep, u have couple of months before your trannys go out. my went out at the end of feburary. i had the rough shift problem for since last summer. now the car sits in the drive way waiting for its tranny swap.
Experience is the worst teacher; it gives the test before presenting the lesson. Why do you need the cats when u have dogs 04 WRX - TOTALED 3-5-05 Previoius Owned: 96 Contour LX with svt kit
I had this problem two yeasrs ago. The o/d light would blink and it would shift hard into second. I had the tranmision flushed out, and it went away. about 20,000 miles later and it's never happend again .
1996 Mystique GS Zetec, ATX
O
O
what happens when it goes out?.........my light blinked the first of this month......changed fluid ,& it's been working well since......if it's only got a couple month to go , maybe I better unload it now...
when it goes its BAd mine strated that and now i have no tranny with all sorts of broken stuff. but hey look on the bright side order your self a shift kit and a nice new upgrade turqurconverter and wha la a whole new tranny at the same price they will charge you for the same thing you have know... I think..... i am in the middle of doing mine.
Go Army My new home for awhile.
