Posts: 2,023 |
How is the C5 Z06 Corvette have such a good Cd despite the lack of spoiler and air foil, and the sharp rear window angle?
-Giovanni
One turbocharger. Two intercoolers. All love.
Posts: 10,015 |
Cd is derectly proportional to frontal cross-sectional area, so seeing as the Corvette is so low and squat it's frontal area is small in comparison to it's length. Plus it sits low to the ground so not much air can get under it = less undebody induced drag/turbulence.
It doesn't need a spoiler because the sharp lip on the end of the trunk breaks off the airflow without causing tubulence.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 5,854 |
IIRC there is an air dam under the car that pulls air out and basically sucks the car to the ground.
1999 Silver Frost SVT
#609 of 2760
Posts: 1,757 |
This is pure speculation, so PLEASE correct me if I'm wrong!
Cd is the coefficent of drag. The lower the number the more aerodynamic the car is. A spoiler would disrupt the airflow to provide downforce at higher speeds. By the same token, the disrupted airflow would also increase the coefficent of drag.
Posts: 1,228 |
Spoiler does increase drag (and weight).
Spoiler: Disrupts air flow to lower lift.
Wing: Airfoil to increase downforce
Technically the spoiler reduces lift (Upforce) while the wing creates lift but downward (Downforce).
Most people use the terms interchangeably, but there is actually a difference.
Having said that, since no moving air actually hits the factory spoiler (at least on my 'tour) because of its location, it is just cosmetic.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 5,725 |
other fast cars that don't have ridiculous spoilers and wings:
Acura NSX Audi S3, S4, RS4, S6, RS6, S8 BMW M3, M5 Honda S2000
Just goes to show that excessive wings and spoilers are really more for SHOW!
For Sale:
- Sony PSP with a Baseball 2k6 and the movie Crash. $100
- 1973 Karmann Ghia Convertible w/ Auto-Stick. Needs Restoration. $1200 OBO
Posts: 2,023 |
Originally posted by baco99: Acura NSX Audi S3, S4, RS4, S6, RS6, S8 BMW M3, M5 Honda S2000
I was referring to the slope of the C5 Z06's rear glass when I was referring to the "spoilers and air foils"...the cars mentioned have very different body shapes.
-Giovanni
Posts: 2,023 |
Originally posted by Stazi the Aussie: Cd is derectly proportional to frontal cross-sectional area, so seeing as the Corvette is so low and squat it's frontal area is small in comparison to it's length.
Drag is a factor of Cd, frontal area, and speed. Cd is independent of area.
Originally posted by Stazi the Aussie: It doesn't need a spoiler because the sharp lip on the end of the trunk breaks off the airflow without causing tubulence.
OH! So it does have a spoiler, I just could not see it in the picture. I have not seen any Z06 C5's in person. Thanks for your help.
-Giovanni
