#57195 04/01/02 08:20 PM
My best guess as to why I'm still getting a "too lean" CEL and surging idle is a vacuum leak. (The idle is worst when cold.) But the weird thing is that cleaning the MAF seemed to fix the problem for a short time, after which it came back. Maybe there was both a dirty MAF and a vacuum leak, and the leak is worse now than it was then...
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#57196 04/01/02 08:27 PM
Sure its not the o2 sensor, i got the same error, i found out its my upstream bank 1 sensor, but i still have to change it, probably tommorow.
98 SVT
MODS:
Something or another
#57197 04/01/02 08:40 PM
dudes, before you go and change your o2 sensors, do what i did. i too got code 171, which means bad o2 sensor. i unplugged my connectors on the one by the manifold. cleaned it and blew it out. reset the computer, and the cel light hasn't come on since. its been about 1000 miles too. my last tank i got 27 mpg. so a bad connection or dirty one could be causing your light. i paid the $80 for a diagnostic check at my dealer for nothing. but it probably is getting old, after all its stock with 103K on it. i will also clean my maf to see if it helps anymore. try this, it may save you some dough.
i will always have a comeback! :o)
#57198 04/01/02 08:45 PM
i did that too, sort of, i took it out blew it through it even with a pump to really blow it out, put it back in, did not reset the computer though, still have the light.prob should have reset it , but wouldnt it turn off if it worked properly.
98 SVT
MODS:
#57199 04/01/02 09:05 PM
Try that before sending $$$ on a sensor.
#57200 04/02/02 09:20 PM
That's a good point, I recently messed with the O2 sensor connectors to check their voltages. Maybe they got gunked.
