#57187 04/01/02 07:34 PM
I have hard water stains on my hood that won't come out. The person who owned my tour before me never waxed the danm thing. She parked it in a car port and water condensation would drip on it every mourning. I tried mothers clay bar and 3 step polish. I even tried turtle wax rubbing compound, a bad idea yhat didn't work. Does anyone have any suggestions(other than new paint), maybe a color matched wax confused ? .
91 Honda CRX
Bilstein shocks, Tenzo R springs
96 Ford Contour LX V6 ATX
KKM intake, Ford Motorsport 9mm wires
All Kenwod Stereo System - 134db
KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
Before you claybarred it, did you strip it of any old wax? In case you didn't know, Dawn is pretty good for this. I don't know that a claybar would remove any wax if it was there and the spots may be under the wax. My best guess.
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
In extreme cases it is necessary to just repaint if the hard water spots are too badly etched into the paint. I have seen limited success with an acid bath with pool acid, but I don't know the proper dilution. This must be done with extreme care so don't try it unless you are familiar with using such harsh chemicals.
Jim Johnson
98 SVT
Before the last time i waxed i washed eith 2 gallons hot water and about half a cup of dawn. I'm going to try again in may or june when it gets warm again. Thanks for the suggestiong guys. 5 stars to ya both.
91 Honda CRX
E
E
D Davis is right, with the wax having to be ALL off before you claybar it. The claybar will not strip off any wax. You should be able to notice a difference after ALL the wax is gone(dull finish, rough surface, etc.). Then the claybar should work. However, if it is acid rain, repaint is the best and easiest way to fix it(acid rain eats through the clearcoat, which will never come off.)
Good Luck!!!!!
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
maybe try some white vinegar...longshot, but just maybe...
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
strip the wax, and use a polisher.. buff the crap out of it. Perhaps wetsand it. Don't do either if you don't know how to do them, spend the money and get it done professionally
1998 Contour SVT
Black
B&M Short Throw
That's what I do if I wash my car at the house cuz we have VERY hard water. I mix it w/ water though, but maybe straight would be able to remove the spots if they've been there a while. smile
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
