#603491 04/14/03 07:36 PM
I've got a 95 Mystique that I'm dropping a 2001 3L into. I'm trying to use the whole new motor, but I'm having some difficulties getting the old return-style rail with the fat injectors to fit.
My end goal is to fit the 3L LIM with 19# injectors.
I figure I'll need to splice the new injector plugs into the old harness, then take the new rail and run feed and return fuel lines to match up with the quick-connect ends of the old rail, plus the pressure regulator.
Wires are easy, especially if Brad chimes in with the correct polarity but I just don't know what to do with the rail. Specifically, the practical aspects of running fuel-compatible hose and making connections that are guaranteed not to leak.
I'm also working on machining aluminum adaptor plates to fit the 2.5 LIM to the 3L heads, but I'd rather not go that route.
Any help is appreciated.
'00 CSVT #570 - 3L hybrid '95 Mystique - 2001 3L
#603492 04/14/03 08:02 PM
Redneck Troll
Redneck Troll
The injectors share a common side, then are individual on the other side of each individual injector circuit. A simple volt/ohm meter or test light can be used (provided the ECU has no power, test light + ECU power = danger) to determine which leads are which. As long as you have the engine harness to the 3L, you shouldn't have any problem figuring it out quickly, unless your electronics skills are lacking, in which case you wouldn't be splicing your own harness. Good luck.
#603493 04/15/03 01:17 PM
Thanks Brad, it doesn't sound too hard.
Frying the computer is not a concern, since both wiring harnesses are on the opposite side of the garage.
Now, to find safe and reliable fuel line connections...
#603494 04/15/03 02:05 PM
Have you tried a 98 SVT fuel rail, I think it will fit the 3L and is the return style. I have not gotten to that step on my project ( 2001L in a 95SE ) Are 98 3L returnless motors? You could use one of those fuel rails too. They should mate up to the car without a major hassle.
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
#603495 04/15/03 05:03 PM
I hadn't, that's a good idea! Just have to find one to check it out.
Anybody have a picture?
#603496 04/15/03 05:28 PM
the 2.5L fuel rails will not bolt up to the newer 3.0L lower intake manifolds
2000 Cougar V6 MTX 2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN Nearly all suspension mods Big ass stereo ...and more... See Her Here
#603497 04/15/03 07:00 PM
So much for that, then.
What did you use to connect your hacked-up rail parts to your fuel hose?
#603498 04/16/03 02:30 PM
3.0 fuel rail, cut just before it's funky bend. Added 3/8" fuel injector hose with fuel injector clamps rated for 100psi. from there it goes into a 2.5L fuel rail which connects into the fuel pressure sensor unit.
#603499 04/16/03 10:34 PM
The wiring isn't hard to do. Just make sure you find the right ground wire. I wired all of them reversed, and had to do them again. Good thing I realize they were reversed before I hook everything up.
#603500 04/17/03 09:04 PM
i guess im lucky my 97 wiring has the same plugs to the injectors as the 98 3L fuel injectors.
ADAM NYGAARD 97 GREEN GL MTX 3L HYBRID, 3L UPPER AND LOWER INTAKES, 24# INJECTORS, RES. REMOVED, INDIGLO GAUGE FACES. 98 BLACK TAURUS SE 3.0 DURATEC
