Hey all,
I posted a while back about a grind that occured intermittently when I shifted from first to second. I was assured that if the tranny cocktail or tranny fluid replacement didn't work, it was likely my synchro going. Well, I've had the tranny out and the second gear assembly replaced. At that time I also had the clutch replaced. Does anyone have any other suggestions about what it might be?
Thanks!
Black E1
F
F
sounds like the repair wasnt done properly or somthing was overlooked or it was never done at all its a synchro
Well,
I saw the hardware they took out, and I wasn't charged for the labour on the clutch replacement. I also have the invoice with all of the part numbers replaced.
Next?
Black E1
They should have change *1st/2nd gear syncro hub*1st and 2nd gear blocker rings*that should be 7 parts in all as first and second gear have 3 part blocker assy's..
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Hmm... is it possible that when second gear grinds its the times you forget to push in the clutch pedal? :p laugh
seriously, I'd run it by Ford again and complain about it. It is entirely possible they didn't replace all the necessary components.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
1
1
Mine does that in 2nd, 3rd, and sometimes 4th when the tranny is cold and the tranny was rebuilt half a year ago. It's worse when I pulled the left side CV shaft and had to top off with just ATX fluid and no friction modifier. I guess I'm going to change the fluid again.
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
F
F
so maybe its not the car but the driver, next?
That must be it. Thanks everybody!
Black E1
if it is still grinding, check out the shifter cable/linkage.
solved my problem.
~Matt
solved my problem.
I'll look into it. Thanks Matt!
Black E1
