cgram, what's up, well, if it makes a "clunk" like parts hitting or a part broken just get back there and under the car and have someone get in the car and move around, and look or try to pin point the area that the noise is coming from and post if it's a suspension thing or the wheels.
But, it just might be your rear brakes if you use your e-brake when you park. If you leave your car outside or inside (very noticeable after water has settled on your discs after a good rain or washing the car) and you go to move it, it could just be your rear brakes letting go from their "locked" position from when the car is parked. If you have discs in the back just move your car back a few inches next time you move it after it sits (preferably after washing it or a good rain, just something to get the discs wet) and put the car and park, get out and check your discs, if you see the outline of where your pad was locked on, then most likely that was it. And if that's not it, then someone else would gladly explain what it may be. I experienced the same thing on my car after i wash it and it sits, but, it may be different, so, check it out next time it sits and you move it.
