#56995 03/29/02 01:56 PM
I
I
I took my car in to get an oil change & tire rotation. After I got it back there has been a smell coming out of the air vents when the ac is on. It smells like a dirty restroom. I think the someone took a piss down my vents (not really but it does smell like it). Service Mgr said it should go away after I start running the ac regularly. Hasn't helped. Is there a cabin filter that needs to be replaced or is something wrong with my ac? Someone please help me or I'll go crazy this summer. confused confused
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
Cabin filter should be replaced every 15,000 miles or once a year IIRC. Darn micron filters get moldy quickly... Check the FAQ pages out for tips on changing it yourself... I think someone took a piss in mine too wwwwwwwwwwwwwwwhhhhhhhhhhhhhheeeeeewwwwwwwwwwwwwwwwwwwwwwwwwwwwwww!!!
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
You could very well vave mildew buildup in the condensor (I think that is where it builds up). I have heard some Lysol can clear it up...
1991 GVR4
Lots of mods done.
Probably your local free ranging tom cat. Just kidding.
Changing the cabin filter often helps, but often you should do more as well. You need to kill the mold and bacteria that can grow on the evap core and in the a/c plenium. Dealerships have a special disinfectant and a special sprayer to apply it. The sprayer has a long hose with an ultra fine spray nozzle. Usually the resister pack is removed for access. After application, the disinfectant should be left without using the fan for at least 1/2 hour.
You can often do a lesser but usually acceptable job with Lysol spray while you have the cabin filter out as you are changing it. Choose a Lyson scent that you can live with as it will be strong for a few days. With the cabin filter out, turn the a/c fan on at a medium speed and spray the Lysol into the chamber thru the cabin filter port. Use about 1/3 to 1/2 of the can. Shut everything down and finish installing the cabin filter. Allow to soak in for at least 1/2 hour. Even longer is better, such as overnight. Remember that you want to kill the micro organisms that are generating the odor. If you don't like the smell of Lysol, then the cure might be worse than the problem.
Wynns sells a product called Aeroscept (sp?) that works very well, but it is intended for professional application and would be nearly impossible to find for a do it yourselfer. Pep Boys used to sell a product called the "Odor Gun" that was scentless and worked very well, but I haven't been able to find it for a couple of years.
It does help to turn off the a/c and turn the system to vent about two to five minutes before shutting the car down. That helps to dry out the chamber so that the moist conditions that the micro organisms thrive in.
In extreme cases, the evaporator core must be removed from the car and the outside thoroughly washed with a bleach and hot water solution. I have never seen a Contique that needed this extreme treatment though. On the cars that did need it the growth on the core looked like a fine green moss.
Also for extreme cases, there is an "afterblow" kit available. The afterblow kit turns on the fan for about 5 to 10 minutes after the ac has been shut down and the car is parked for about 1/2 hour. There is a TSB about it. If you are out of warranty, it is a bit pricy, but worth knowing about.
Jim Johnson
98 SVT
cabin filters are $8 at Autozone.
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
