Posts: 98 |
Got a question for all. And I already did a " Search ", so back off nazi's. There have been a ton of posts on duals and people installing them, my question is simply this.....On a 4 cylinder, which is the better way to go? Not talking about aesthetics, simply performance. I am not trying to start a pissing contest, just looking for the facts. I don't have enough background with 4 cylinder engines to make a good decision.
My background is with V8 muscle cars, headers, and dual exhaust. Building them from the ground up. My plans are to build one hell of an engine for this car.
Any and all advice and knowledge is appreciated.
Thanks in advance.
TOUR'ING
Posts: 439 |
From a purely performance standpoint single will net you the best gains, but a quasi dual system will probably sound and look better.
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
Posts: 21,653 |
If you use small enough pipe on the duals, then it would perform same as single exhaust. Dual exhaust actually helps your mid and high end better than single. So maybe you only care about low end... I doubt that though. And if you build an engine pushing over 150hp than a dual exhaust should be find even on the low end.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,975 |
So then what is the recommended diameter for single exhaust, bigger isn't always better with 4-cyl engines right? Do you actually need a little backpressure in the system, so that 3in. wouldn't work?
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
CEG road warrior
CEG road warrior
Posts: 17,248 |
Somebody didn't search.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 3,465 |
it's all a matter if what you got for mods other than the Exaust... weather it's a single or a dual.... to keep a stock air box and a dirty paper filter and no matter what you did to mod the exaust it isn't gonna help you that much.
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 8,143 |
Originally posted by ZetecRacing: to keep a stock air box and a dirty paper filter
hey thats what I have! its awesome for ripping away your throttle response.
Posts: 439 |
Posted by kremithefrog Quote:
Umm, no, a dual exhaust has more bends(slowing down exhaust flow), more piping and an extra muffler(again slowing down exhaust flow and adding more wieght to your car).
Wrong again, the only reason paople are seeing better mid and high power(and a small drop in low end occasionally) from the SVT exhausts is because they are pretty much switching straight from the crappy stock exhaust right to the SVT quasi-dual. I can assure my single SCREAMS up top.
The only thing that should change with increasing HP is pipe diameter, duals/single really doesn't come into play.
Posts: 472 |
so what have i done? i switched to the svt exh with a magnaflow resonator, killed my low end? improved the mid range? i know it sounds better, but is that it, it felt like i picked up a bit in the mid range, but who the hell knows there is so much conflicting info here, the best way to have found out would have been to dyno before and after the exh, i wish i did to end these discussions
96 gl sport, atx, rip at 95k
FDNY 343 remember 9/11
Posts: 3,465 |
Originally posted by ohsigmachi: Umm, no, a dual exhaust has more bends(slowing down exhaust flow), more piping and an extra muffler(again slowing down exhaust flow and adding more wieght to your car).
 mine doesn't have 2 mufflers and what do you mean more bends in it mine just has a split where the bend would be for the stock single exaust.
aka ZetecRacing
