Posts: 12 |
Hi, I would like to know if it is safe to reset the car's computer ? does it has any consequences ? I got to be sure before doing it.
Thanks.
Tobah
95 Zetec GL 2.0
Posts: 2,319 |
Go to FAQ section on home page, then HOW-TO section.
Radio and clock may have to be reset, if you disconnect bat neg cable to do the reset.
Posts: 1,247 |
You are supposed to pull fues #4 and #11 from the power distribution box underneath the hook. Leave them out for about 2 minutes. You won't have to disconnect your battery which is a good thing.
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 2,807 |
Originally posted by 2KSESport: You are supposed to pull fues #4 and #11 from the power distribution box underneath the hook. Leave them out for about 2 minutes. You won't have to disconnect your battery which is a good thing.
This is done to erase the KAM Keep Alive Memory. Once done you are ready to go. I often wonder if it would be easier to disconnect the battery, it's a cramed space around the under hood fuse box and a PITA to remove the cover.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
