jayball Offline OP
Hi everyone.
I recently purchased a 96 tour, zetec auto.
When stoped at a light, there is a noticable vibration in the steering wheel. It lessens if i shift to neutral or park. It stops all together when I accelerate. Any suggestions. I'm off today to get some new pulgs and wires.. any info on the best ones to use?
Sounds like your tranny fluid is due for a change. When it gets old, there will be more slippage in torque converter plate, leading to what your feeling. I'm getting that same thing on my '94 Taurus wagon, and I just changed the darned fluid. Didn't help much, hope that thing holds up for one more year...
Rob Weiss
'99 Mystique, 2.5L, MTX,Black/Tan, 37K miles
SVT Air Intake & Throttle Hang Plug
Build Date: December 14, 1998
jayball Offline OP
Thanks for the advice, however that should not be the problem as the entire tranny was replaced less than a month ago.
Well, scratch that idea.
Motorcraft or regular Bosch plats are fine. Just make sure you get the service plugs that are platinum coated on both electrodes. Couldn't really advise on wires.
How old is your coil pack? If it's original equipment, it's probably fading.
Rob Weiss
jayball Offline OP
As far as I know, the coil pack is original equipment. Thanks for the 411 on the plugs.
Where is the coil pack located on these cars?
Where is the coil pack located on these cars?[/QB]
Follow the spark plug cable from the plugs and you will find your coil. :p
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
MFE Offline
Mine used to do the same thing, the idle is just a little too low IMHO but there isn't any thing I know to do about it. it got better after I sprayed the MAF element with carb cleaner and followed up with brake cleaner.
Pacific Green '96 Contour LX V6, loaded
'98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the...
Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
I have the same problem plugs won't fix it. I have a feeling it is the IAC. I will be replacing mine next week. My car has been doing it for over a year so it isn't anything major. I went as far as to change all the mounts. So i'm sure it has to be the IAC. But could be wrong.
95 contour (All the usual mods and then some.) Trying to sell four wheeler so i can buy turbo.
MY CAR WAS IDILING ROUGH. COME TO FIND OUT MY ALT. WAS BAD. I HAD IT REPLACED AND IT IS FINE NOW
99 green se
I've done put two different alternators on it still not fixed.
