#598393 04/08/03 09:35 PM
CSVT19 Offline OP
My 98 SVT all of a sudden won't start. You can hear the starter motor turning when you turn the key but the engine won't fire. It's been raining so might that be a problem.
'98 Black CSVT BAT Filter w/ Inlet Pipe '84 Nissan 300ZX Turbo
does the engine turn over at all.... if not then the thing on the started that kicks the starter wheel out might be toasted and the started motor is just spinning but it is not hooking up to the flywheels to start the car
Trollin the boards as of 9/23
Originally posted by GS474:
stock hp is never enough
It could be the Idle Air control valve. If the engine is spinning then you can probably get it started by holding your foot on the gas a little to crack the TB. From what I have found is the IAC will start working after a little bit of it running like this. Good luck.
Green 2000 SVT #1166 mods-K&N and Custom heat shield, optimized y pipe, Magnaflow center resonator, DMDhttp://www.geocities.com/savinoss/Cars.html -Wifes car 99 Mystique V6 5 spd
My car pulled this on sunday morning. I just put my foot on the throttle and she fired right up. This is the 2nd time this has happend to me.
2006 Fusion SEL (Fully Loaded) Fusion Boards 1992 Thunderbird 3.8 V6 Former 1998 Contour SE Sport owner
