Posts: 49 |
Hey, i have a JVC 40x4RMS amp right now for my doors powered by 4GA wire, I am adding another amp for subs, the Bazooka EL1500 500x1RMS at 2ohms (which i'll be running 2 4ohm subs in parallel for) How would you recomend I power these things. If its at all possible i would like to do this fairly cheaply. Should i get a dist block or can i "daisy-chain" them or is there something else i dont know about? Thanks!
1995 Mercury Mystique GS V6 MTX
Pioneer 6x8s in front, Pioneer 10's in back 1200 watts powering it all
KKM intake
SVT Exhaust Swapped out resonator for Glasspack
Mobil 1
Brand New!! Giant scratch on front bumper and right side!! Yes!!!
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Rookie opinion: A distribution block with seperate fuses would be my guess for the best install! I think 4 guage should be able to handle both amps!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 8,301 |
Originally posted by Andy W.: Rookie opinion: A distribution block with seperate fuses would be my guess for the best install! I think 4 guage should be able to handle both amps!
-Andy
I agree. I wound not daisy chain them.
-Ken V.
psycho_bass@hotmail.com
Posts: 7 |
I run 2 amps and just ran 2 seperate 6awg lines off the battery itself with a 60A fuse in each line..works great
'95 Contour GL 2.0L Zetec..no mods..yet..
replaced head unit, all 4 door speakers replaced, 3 subs in trunk
Posts: 1,279 |
Originally posted by 4cylpower: I run 2 amps and just ran 2 seperate 6awg lines off the battery itself with a 60A fuse in each line..works great
He already has 4ga, no sense in running a new line, best option is to use a fused distribution block. Connect the 4ga to that and you can use 8ga from the block to the amps
Previous Owner of 00 SVT Contour #1077/2150 ![](/ubbthreads/images/graemlins/frown.gif)
95 Contour SE '01 3L
Posts: 49 |
will i be ok with only 8 GA going to the EL1500 (500 RMS and it actually puts that much out, not like the pyramid crap i used to have)
KKM intake
Mobil 1
