There is a Ford dealer selling out all tools, and I waswondering iof anyone knew what Rotunda toolkit had the suspension subframe alignment tools?
Any others that might be nice to have?
THX!
Lee
98 Black SVT
F
F
Yes there in there.....here is what was in my kit..
Ford tool kit number T94P-1000-FH/FLMH. This kit contains; (The following tools are for the 2.5L engine);[1]- Connecting Rod Guides, [2]- Camshaft Seal Protector, [3]- Camshaft Seal Replacer, [4]- Camshaft Damper Replacer, [5]- Water Pump Pulley Remover/ Replacer, [6]- Water Inlet Tube Replacer, [7]- Valve Guide Replacer Adapter, [8]- Valve Spring Compressor.
The following tool is for the 2.5L and Zeta engines; [9]- Valve Stem Seal Replacer. The following tools are for the Zeta engine; [10]- Valve Stem Seal Remover, [11]- Valve Guide Replacer Adapter, [12]- Valve Spring Compressor Adapter.
The following are for the MTX-75 Transmission; [13]- Measuring Fixture, [14]- Shim Selection Tool Adapter, [15]- Bearing Cup Replacer, [16]- Differential Drive Shaft Seal Replacer, [17]- Selector Shaft Bearing Remover/Replacer, [18]- Pinion Spline Socket, [19]- Gear Lever Aligning Tool, [20]- Differential Bearing Cone Replacer, [21]- Selector Shaft Seal Remover/Replacer.
The following tool is a chassis tool; [22]- Sub Frame Alignment Pin Set.
The following tool is for the power train; [23]- Power Train Alignment Gauge.
The following tools are for the CD4E Transmission; [24]- Transmission Range Sensor Tool, [25]- Servo Plug Replacer/Needle BearingReceiver.
Excellent & THX!
Lee
98 Black SVT
