Posts: 2,807 |
Sometimes at start-up on my 96 Contour I hear a clicking sound comming from the rear passenger side of the car. This will laast for 20 seconds or so and then stop. I am wondering if this could be the fuel pump? It happens at all levels of fuel from full to near empty and has been doing so for a couple of years now  . Is this a precursor to a fuel pump failure or could it be caused by something else? BTW I change the filter regularly so a cloged filter is out of the question.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 3,506 |
Yes, the pump is underneat the back bench seats...Well for the duratech...n-e-ways, clicking sounds like your fuel pump, are you having any problems with your fuel gague too?? I must warn you, if you go to the dealer (like i ahd to) it will cost you about 250 brand new....and thats for a new pump and fuel level sensor...for my SVT (1999 returnless system) thats the only way they come, I believe 1998 with return fuel systems can get the parts seperatly.
Roz
Posts: 2,291 |
Originally posted by Roz 1999 SVT-C: Yes, the pump is underneat the back bench seats...Well for the duratech...n-e-ways,
Zetec is too (just in case this is ever pulled up in a search and the info is needed).
Posts: 3,506 |
thanks....i wasn;t sure of the ztecs and i didn;t want to say something that was wrong.
Roz
Posts: 2,319 |
When key is turned to on before starting engine, one should normally hear what I would call a whirring noise from electric fuel pump for a few seconds as system is pressurized. Length of time will vary depending on how long car has been idle.
If this is what you're hearing then it is normal.
Posts: 64 |
Did your contour come with a power anttena? My Mystique Did and when the anttena quit going up or down I heard a clicking noise from the rear passenger side until I unhooked the power from the anttena.
Posts: 2,807 |
Originally posted by horseydug: When key is turned to on before starting engine, one should normally hear what I would call a whirring noise from electric fuel pump for a few seconds as system is pressurized. Length of time will vary depending on how long car has been idle.
This is not a pressurizing noise this noise persists for the aformentioned 20 seconds after the car is started.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,807 |
Originally posted by Tribal: Did your contour come with a power anttena? My Mystique Did and when the anttena quit going up or down I heard a clicking noise from the rear passenger side until I unhooked the power from the anttena.
I do not have a power anteena.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,319 |
Re-reading your post I notice you said rear pass side. Have you confirmed noise location by listening with trunk open? Fuel pump is on driver's side.
Edit: Correction, pump location is under center hump of car.
Posts: 2,807 |
Originally posted by horseydug: Re-reading your post I notice you said rear pass side. Have you confirmed noise location by listening with trunk open? Fuel pump is on driver's side.
I have not done this. What will having the trunk open do for me? The biggest problem diagnosing this is that it it intermitant. It doesn't happen all the time so I don't know when to have the trunk open.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
