Replaced the water pump on my Mystique ('97, alloys, V6, otherwise stock) last weekend. Found something a bit interesting along the way that I thought I'd share...
Those of us who have been around cars a little know what the area around, and especially UNDER, the battery can look like. Sooner or later, a little bit of acid will find its way out of the battery and drip downward. Between that and maybe a little galvanic action, it's no mystery why the area always gets a little rust.
This is a salute (see that finger there?) to the genius at Ford that decided to route big, fat +12 volt wires UNDER the battery, at least in the Mystique. While working on mine, I noticed a loom of wires going between the fuse box next to the battery and the positive battery cable. The insulation on a few of the biggest ones was just cracking and flaking right off! Yes, that's right - big, fat, bare wires connected right to positive battery just dangling about in the engine compartment. All you need is good contact with any of that other metal down there and you get a dead short to ground. Worst case, you weld a little and blow up your battery. Even a little contact, and you might see a recurring problem with strange battery discharge and that nasty burnt insulation smell under the hood.
Well, I fixed it for now. I repaired the offending wires and protected them as best I could, but was unable to reroute them just yet. Oh yeah, if you want to solder wires that have been corroded a bit with acid, be ready with lots of rosin flux and a big iron. You'll also want to clean it up when you're done. (I use rubbing alcohol and a little acid brush)
Just thought people should know...
Edit: Subject changed.
